configure cfm segment frame-loss mep
configure cfm segment segment_name frame-loss [add|delete] mep mep_id
Description
This command is used to add/delete the local MEP for a given CFM segment.
Syntax Description
segment_name
Alphanumeric string identifying the segment name.
frame-loss
Y.1731 Ethernet frame loss measurement.
Default
N/A.
Usage Guidelines
The MEP with the given MEP ID should already be created in the system. The domain and association for the segment should be configured before executing this command. If the domain and association are not configured, the command throws an error.
Configuring of local MEP is mandatory to start the Frame Loss measurements.
configure cfm segment cs2  add mep 3
configure cfm segment cs2  delete mep 3
This command was first available in ExtremeXOS 15.1.
Platform Availability
